wrigh003
I have a half basement/ shop that I am getting started on finishing. Biggest air leaks into the space are the garage door (easy fix, just have to spend the money) and a big void over the partition wall that separates the area from the uninsulated crawlspace. I'm going to attach a crude diagram because that's the easiest way I can explain what I am talking about.
That's a cross section of what I am looking at. The horizontal line is the floor, with the joists under it. Between the joists, sticking up, is the concrete block partition wall that defines the space.
My question: What's the best way to seal this gap? I was flipping through a Family Handyman the other day and they recommended a piece of fiberglass batt in a plastic bag (I guess a heavy-duty contractor trash bag) to seal up a big gap. Is that the best way, or is there something else I should look at? This is the same space that I have been working on for a while now, by the time I get it done, it'll be finished living space/ rec room as much as workshop, so please keep that in mind.
Maybe I can make that happen this evening.
