twostory
I installed my Mr Heater 45,000 btu heater this weekend. I have a propane tank outside the garage. I put a regulator on the tank with a rubber hose.
The hose connects to a black iron pipe at the exterior side of the wall. The black pipe has six 90 degree fittings, 2 unions, and a few couplers. The pipe is 1/2 inch. The black pipe goes all the way to the heater connection.
I used the yellow pipe sealant on every connection and all the fittings are firmly tightened with a 14 inch pipe wench. I bought the pipe and fitting at home depot.
My problem is the system does not hold pressure after one hour. I turn the gas to pressurize the pipe, then turn off the valve on the exterior wall where the rubber pipe connects to the black pipe. Thus removing the propane tank, regulator & rubber hose from my system.
After one hour, I turn the propane tank back on, then open the exterior wall valve. I hear the gas rush into the black pipe system. I have sprayed soapy water on every fitting and do not see and bubbles. I can not smell any gas, even if I leave the propane tank connected for an hour.
I also have a cut off valve right at the heater. If I run leak test, with the "heater" turned off, the result are the same. So I do not think the "heater" is leaking gas.
My question, any thought on how to find my leak?
Thanks in advance...
