FinallyAGarage
- Joined
- Oct 23, 2023
- Messages
- 1
I will soon be closing on a house with a 3-car garage, appx 25x30. The driveway has sunk an inch or so at the garage, creating a negative grade. The garage floor itself does not feel uneven but has a small crack running half its length and has obviously settled to the point that a structural jack post is loose and the upper structure of the house has sagged. Water drains to the centerline of this floor. I'd like to level the floor with type N morter and install porcelain tile, but want to make sure there won't be future movement. Structural engineer says the negative driveway grade isn't helping by moving water underneath the garage slab. He also mentioned builders of these homes weren't always attentive to soil structure specifically under the garage floor.
So raising the driveway is first on my move-in list. I've called three places. The poly lift place asserts superiority of foam to slurry, which checks out if erosion were an issue. I had assumed foam compresses over time; it's unclear to me whether it does. The other option I suppose is to remove & replace the whole floor. I can only imagine what that will cost. I am looking for a permanent fix so I can lay tile, re-jack the house up, and forget about it. Do you think lifting the driveway and maybe the garage floor will do it?
