8man
I am working on a 48 Chevy pickup and 2 of the four bolts holding the hood to the hinges have stripped the nut built into the hood. The nut is built into the hood support and I can't get to the back side, and it will be a real pain to get the supports off to work on the back side.
The hood bolts are 5/16" -20 with a shoulder that the hinge rotates on. That shoulder makes a tight fit so it doesn't move around. The PO drilled out one to a 3/8" - 16 and put a plain bolt in the hole. That bolt allows the hinge to move around and won't allow me to set the hood properly.
I've been told nutserts or rivnuts, but I don't have the room on the back side of the support for that.
Is there something else that might work? I can drill it out and tap it if there is something else.
I would appreciate any help on how to fix the nut.
