How to fix sagging rectangular duct work?
knucks
Not in my garage, but in my crawl space, I have HVAC ducts whose clamps are broken/coming off, and my ducts are sagging. What is the best way to repair?
I don't see how I could get into the space between the wood jousts and the top of the air ducts to bend new galvanized strips in the same shape..
Any tips or tricks? Additionally what do I need to be able to squeeze a long drill bit or similar between parallel ducts? I have some clamps broken in between two ducts..
Kenstone1
Remove those nails. Bend the "flange" 180 degrees the other way. Now you can easily nail or screw them to the joist since the tail of the flange is no longer above the duct.
this^
and use screws not nails
You could cut the nails flush to the floor joist with a saw-all or a Oscillating Multi-Tool, way easier than trying to pull those nails.
jmo,
Innovate1
For the tight spaces between the ducts it may be easier to just add another bracket. Then use a long extension for driving screws into the new bracket. Metal pipe strapping (think that's what it's called - the strip with holes you can get in a roll) could be used and is readily available. Screw it to the bottom of the duct or run it all the way under and screw it to the joist on the other side.
