I am making a workbench with a 74" X 39" X 3/8" thick steel plate. The plate is not flat. Any recommendations on flattening the plate? I do have an oxy/acetylene torch. If I use a torch which side of the curve, should I heat up? Or any other recommendations would be grateful. The plan is to attach a 3/4" thick melamine sheathing on top of this plate for woodworking and I want it as flat as flat can be. Once I get it flat, then I am thinking of applying a liquid epoxy or glue over the steel plate and laying the melamine down to float on the liquid and that may flatten out any remaining curves.
Thanks!
Thanks!
