And in general, why would some cars use lug bolts, instead of lug nuts? Lug nuts are so much easier for owners. About the only advantage of lug bolts is that they are easier to work with aftermarket wheels, and wheel spacers. Is that right?
/Thread.Place a lug bolt and the required socket through one of the holes. Lift the tire onto your knee as you place it against the hub. Lean forward slightly while standing on one leg, which will keep forward pressure against the wheel and stabilize you while tightening. Ideally clock the wheel before lifting it up so it's somewhat lined up with one of the stud holes. I prefer to use holes visible from above while standing, so anything from 9-3 o'clock is preferable.
When on jack stands, do the same except lift the tire onto the hub first. Then place your foot underneath for stabilization while you start the bolt with the socket you already placed in one of the holes.
You can also buy hangers, which are just long studs to make this easier. If I was going to DIY, I'd buy the hangers. When working on a rack, the method I listed first is very easy so I never bothered buying them.
Came here to suggest something like this. I think I used the exact same set a couple of times at a friends shop. Also if it is your personal car I would install studs as soon as possible. It is only a nuisance to have to deal with at home, but imagine having to deal with it on the side of the highway if you have a flat.I've been doing what 2nd posted for the past 17 yrs. Since I've been having to work on Euro's more frequently I finally broke down and bought the lisle set. Actually just got delivered yesterday and I'm sure I'll put them use this week at work
The car came with a hanger, in the tool kit. It's probably plastic, but it will work. If it's still there.... Single metal ones are available, and greatly ease side of the road wheel changes.Came here to suggest something like this. I think I used the exact same set a couple of times at a friends shop. Also if it is your personal car I would install studs as soon as possible. It is only a nuisance to have to deal with at home, but imagine having to deal with it on the side of the highway if you have a flat.
In the years since ballers/wannabees running "dubs" became a thing, the local wheel repair shop takes the entire staff to Hawaii for a week in the spring on the profits from that huge wheel/skinny tire combination. He loves it even more when they put the dubs on Escalade/2500 series trucks. In a good winter, they'll bend all four of the wheels.what pushed me to purchase the lisle set was that i had to take off all four wheels on a 2018 bmw X7 for wheel repair. im talking 22 inch wheels with run flat tires weighing 70-80 lbs a piece.
