How to hold wire going outside
Ryland
Rhode Island
I just drilled through for an outside light and the outdoor box that I have doesn't fit the normal 3/8 wire clamps that I have used everywhere else. What should I use to A hold the wire tight and B make it weather tight?
oleguy
is it 3/4"?if so you can get a 3/4 clamp or if you don't want to use that big of clamp,get a 3/4 to 1/2" threaded bushing.then you can use the 3/8 clamp.
