Hi, I moved into my house a year ago and am starting to work on the garage. It is a pole building and the previous owner put r-11 fiberglass rolls on the wall and then put paneling to cover/ for walls. The paneling is dark and does not look good so I want to put up OSB painted gray to brighten up the garage and so I can hang lightweight items on the wall. My question is how should it be insulated? I would like to be able to leave the roll insultion for ease and cost,or should I rip it out and put 1.5in foam board insulation inbetween the 2x4's? If I reuse the insulation should I put the OSB up like they had the paneling ( squeezing the insulation down) or put 2x4 furing strips over the original 2x4's?
Thanks for the help and hopefully someone has had this problem before.
