sevensandeights
For some reason I just can't figure this out and I'm sure there is an easy solution but . . .
I am in the process of finishing up my garage build and am planning the insulation. It is 40x60x13 with 2x6 walls 16" OC. The trusses are attic trusses 2' OC with a 10" bottom cord that give me a 16' wide x 8' tall attic space .
I have radiant heat in the floor and plan to put R-19 batts in the walls and cover with OSB. For the ceiling, I plan to put the white metal siding up directly on the trusses and then blow in R-30 to R-38. My building has soffit and ridge vents so I will put baffles in.
My question is how do I insulate around the actual attic space? I planned to only put OSB on the inside surface of the attic trusses (both on the wall and ceiling). Can I just staple R-19 batts between the trusses all the way around the attic space?
My goal is to have reasonable temps in the attic so I can store a variety of things up there. I don't plan to heat the space but would like to avoid the temperature extremes like the attic in my house that gets up to 100+ degrees in the summer and down to 30 degrees in the winter.
