Mossmilo
I have a concrete company coming to prep my floor tomorrow they are putting the 2 inch insulation down on the floor and the perimeter. The only question I have is my garage has the pole foundation where they put the poles in the ground them cut them off and cap them and stick build on top of that so basically it has a wood foundation. So you just leave the space in where the garage door opening is open with no vertical insisting or ? As far as I know right know I cut all the insulation 2 ft so only 4 inches will be out of the ground up against the wall and the concrete will be flush with the top of the concrete I'm just not sure about the door opening. Keep in mind the driveway is just gravel.
