How to keep drill bits from "biting" so hard?
tearlessj
Hello,
This maybe a very beginner question but I was hoping you guys could give me some advice.
I bought a set of 1/2" to 3/4" drill bits to drill out some handlebar ends and various projects around the house. Everytime I try to use them with my hand drill it catches and yanks the drill out of my hand. The only way I've found to combat this is to use a lot of speed and slow feed. Even then, I still get hooked up sometimes.
Is there a way to re sharpen these or something to make them friendlier to use with my hand drill?
moriboy
Oregon
Use unibits when possible on thinner metal.
Robby321
Olympia, WA
Take a carbide sharpening stone and dull the cutting edge a bit. Did this for (retired Machinist) soft metals, brass and Aluminum...
Moosefire
Detroit
Using a drill press and a vise will help a lot. You have much more control
Sent from my SM-N960U using Tapatalk
rlitman
Long Island
you can lessen the rake angle...
This may help, and will help with grabby materials (aluminum, brass and plastic), but I suspect that the OP's issues are more user caused.
When punching out the back of a piece, drill bits will get grabby. It's because the push up two burrs that they want to tear off at the end. The answer is to feed a little slower at the end as you're punching through, or better yet, drill into a sacrificial backer that your workpiece is firmly clamped to.
Ign
Butte Peak ND
Good advice here.
For drilling cast iron or plastics you can grind 'em near square or they'll self-feed/auger in, but OP's issue is different.
I also agree with the suggestion of unibits. I got a spiral flute Temo upon the PF (Project Farm) review and thus far it's been fantastic. ~10 years ago I loved the HF offerings but I haven't been able to find one that can hold an edge in a long time. Other offerings like Milwaukee or even Irwin seem marginally better for a LOT more $$. But I'll typically only use unibits in materials >1/8"
tarbellb
Oregon
Lots of good advice, to add and repeat:
Use step bits for thin materials
Use a sacrificial backer board
Use graduated sizes to grow diameter
Use a drill press or vise to hold object
Good luck
xela456
Oh yeah, totally! Step bits are the only way I can get reliably round holes in sheet metal. Twist drills give you a trilobular shape.
Put a piece of cloth between your drill and the sheet metal. It give you a nice round hole. Don't know why but it works
Ign
Butte Peak ND
Didn't think I needed to include that disclaimer... don't do these in a hand held drill... there.
Hello,
Burrito?
seber
Deep East Tx.
Drilling out the ends sounds like you are trying to enlarge the opening in the end of a pipe. If that is what you are attempting, then you have the wrong tool. You want a reamer.
PCustoms
VT
I'm glad someone read the OP.....
It's grabbing because he is trying to increase the ID on thin wall handlebars and only taking a tiny cut.
Reamer or hone is the proper tool!
Farmall450
Marengo, Illinois
This, plus poke a small hole then use a unibit. Even the cheap ones work well (and the $$$ ones work REALLY well).
