I need to precisely locate 17 trusses in my roof so that I can install two lag bolts in 102 places to mount solar racking. The composition of the roof is as follows from the top down: decra 24 gauge steel tile (can be removed), Mylar faced 1/8" foam radiant barrier, 30# roofing felt, 3/4" tongue and groove roofing deck, and 2x4 roof trusses.
At the peak of the roof, I have a partial ridge vent. The roof deck was cut for a ridge vent but the tar paper doesnt have sufficient opening to actually function like a ridge vent. So, I may be able to push a paint stick or something up through the peak to use as a guide.
Based on what I have described, does Garage Journal have any thoughts how to locate 17 trusses accurately enough to drill two pilot holes for 3"x5/16" lag bolts into the trusses in 102 locations?
My structural engineer recommended the most expensive version of the stud finder. It is commonly used for windstorm mitigation inspections in Florida.
