How to make this rotator plate
larry4406
Northern Virginia
How would one go about making this rotator plate at home? In particular, the circular perimeter. This is for a rotisserie. I do not have a torch, plasma cutter, or 8" hole saw. I do have a a drill press. The indexed holes are easy; I want the large circular OD.
Thoughts include getting a carbide cutter, mounting the plate to the drill press via a bolt and spinning the plate while engaging the cutter to make the OD (poor man's lathe) followed by a pilot hole saw for the interior 4" hole. Other thoughts include making the interior hole and then using a friend's brake lathe piloted on the interior 4" hole to cut the perimeter.
welder4956
Birmingham, AL USA
Forget the drill press, it's an easy way to get hurt seriously. The brake lathe sounds like an option. I would find a local welding shop to flame cut it, or get a tech school student to do it for a few bucks. Or, use it as a good excuse to purchase a new plasma cutter or oxy-acetylene torch.
murph64
Mohegan Lake, NY
why does it have to be round? how about octagonal?
bob
Yup. It really doesn't matter what shape the OD is, as long as the pin holes are fairly true to the center. A Sharpie, scribe, straightedge and protractor is all you need. Then centerpunch and drill.
Andy
L
larry4406
Northern Virginia
I agree that it the round exterior is not a functional requirement and mitered perimeter would work (i.e, octogon). This is 1/4" plate - will a jig saw with fine blade actually do this? I have contemplated using this as the excuse to buy more tools (plasma, torch, etc).
metal1313
clinton NJ
ive done rounds by hand with a grinder then spent time, lots of it grinding the plate to round. that said a decent jig saw and plenty of oil along with good blades should do the job as well
rsanter
visalia ca
draw your circle, drill a series of 1/8 holes around that line. place them close together but not breaking through. use the jig saw to complete and the grind to a finished circle
look for a piece that is already round that you can retask to what you want.
I have seen scrap places that have round blanks that have been cut out from a plate (where they wanted a round hole) and to that company the blank/plug is scrap
however, if you have a horizontal bandsaw or abrasive cit off saw, the octogon will be the easiest
bob
reinhardt
4 inch grinder w/ a cut off wheel. draw the circle w/ a sharpie, cut close to the line, then grind to it w/ a grinding wheel.
c_mccann
string, sharpie, center punch, drill and a jig saw will get you there.
filtered
Berks Co. PA
I have a friend with a CNC plasma table that can cut that plate for you. All the holes and everything. All you'd need to do is supply him with the dimensions, address to ship to, and payment.
kbs2244
"How about drilling your indexes in a brake disc? "
Great idea.
Do you need that many holes?
An 8 hole rotor will work with little modification.
L
larry4406
Northern Virginia
My plans are as follow:
Drill a 1/4 inch pilot hole in the center of the plate. Insert pin in the pilot hole. Make a fixture to hold a cutting torch, rotate the plate on the pin while cutting the perimeter with the torch. Repeat for second plate. Grind/sand perimeter smooth.
Drill 4 holes in one plate about 1 inch eccentric to the pilot hole. Stack plates and tack weld (plug weld) together via these holes.
Using the pilot hole as pivot, match drill the plates for the indexing holes. Once complete, use a hole saw indexed on the pilot hole. The hole saw will remove the core along with the plug tack welds and separate the plates.
Now all I need is time.
L
larry4406
Northern Virginia
Not perfect, but will work for me. Second plate cut better after installing 2 washers between it and the turntable base - molten slag interferred with rotation.
The first drilled hole wandered off punch - tried to drill the 11/16 hole in one shot. Changed to 1/4 inch thru hole and followed by the 11/16 which self centered and then clamped in to position. Should not have thru drilled as the cutting oil drained out each hole.
Next is drilling out core with 4" hole saw.
bobj49f2
SE Wisconsin
I just came on on this post. I bought a rotesseri last fall to work on my '37 Buick. I got it fairly cheap on eBay, it was custom built by the seller but it lacked being adjustable and I wanted a better way of locking at different angles. I first made all bracing adjustable and use a large sprocket I had laying around but the local farm supply sells for around $30. I drill a whole every 10° and installed a spring loaded locking pin.
As a bought it:
The upgrades I made:
A '37 Buick body is fairly large and heavy, this set up works great.
L
larry4406
Northern Virginia
Here are some additional pictures after removing the core with the hole saw, welding in the pipe sleeve, the index pin with hold-open stop and the final test run. I need to rework the front brackets as I ran out of room to adjust the CG. The threaded rod runs in bushings in the T-arm with washers. The big nut on the bottom I use an imact on to raise/lower to adjust CG.
WSMC633
Los Angeles, CA
Came out nice. Good job! I'm guessing by the shininess of that torch you did end up using the project for an excuse to buy a new tool?
L
larry4406
Northern Virginia
Thank you.
I inherited my dad's old torch and tank set. The oxygen regulator on that stuck and exploded a new hose at the base of the torch handle - hurt my ears, stung my fingers and leg. First instinct was to count all the fingers. I then bought a torch set from HF for ~$100 after 20% coupon. Works extremely nice and appears well made, has a cutting tip and one other tip. The old torch set will likely be dumpster food - it is a Victor circa 1977.
