how to mire compressor motor when the cover is missing
socalmerc
riverside, ca
how to wire compressor motor when the cover is missing
i have a quincy compressor that is missing the cover wiring diagram . i want to wire for 220v and the motor is single phase. is there a standard way to do this or do i have to take it in to have it done. the motor is a balder.
socalmerc
riverside, ca
heres the pics of it
nehog
Jaffrey, NH
It appears (but hard to see exactly) the motor is 208-230 volts (will work OK on 240, btw) already. Can you perhaps clean and reshoot the picture of the motor's data plate?
Charles (in GA)
50 mi south of Atlanta
I'll bet this compressor had a motor starter on it originally and someone cut the wires to remove it. Given the amperage, I'd say it needs a starter.
For general info, and comparison, THIS THREAD and THIS THREAD ALSO deal with magnetic starters for compressors. Both are recent threads. I cannot see trying to operate this compressor without a starter as it draws 26-28 amps, more than the average pressure switch can handle.
Charles
PT Doc
Condor makes pressure switches that have protection up to 30 amps. It is adjustable to the amps that you need. Graingers price is about $150.
DistantHorizon
http://www.condor-usa.com/Catalog/catalog.pdf
Apparently only for three phase switches. Cannot find any for single phase that offer thermal protection.
Charles
I believe he needs to use a 3-phase starter and skip one of the legs. The magnetic starter I just used has a decal inside that tells how many amps it is rated for for both single and three phase.
Compressor guy who helped me out ended up just getting me an old 3-phase starter after his supplier said they could not get a suitable single-phase unit.
