How to polish a steel shaft
Old tool guy
I bought this old hand cranked drill press and I’m getting close to getting it cleaned and put back together, but i have a problem. The steel bar that is the post is badly pitted everywhere except where it was in the base and where the head was mounted. It’s about 1”x15”. What can I do to get it looking good again?
finn
The UP, God's country
Sandpaper or crocus cloth and a rope or leather strap. Wrap the strap around the shaft / paper a couple of times and pull the loose ends alternating directions.
Same method used to manually lap / polish crank pins and journals.
O
Old tool guy
Ok, i understand the sandpaper & crocus cloth (same as emery cloth i presume) but the rope and leather strap? Is that for after hours activities?
Jure
Croatia
Get a new shaft,its just a piece of rod. You can fill it with bondo and repaint. If you dont want to paint it,i would melt a soldering wire and dip the shaft to fill the pitting,sand and polish it. have no idea if soldering wire will work,but that's what I would try.
O
Old tool guy
Original diameter must remain the same? If no,make a lathe pass...
I assume the diameter needs to remain, i don’t know if there is enough give in the clamping parts to accept a smaller diameter. And i don’t have a lathe.
Firebrick43
West central Indiana
If you take enough off the shaft to remove the pitting it will be too small hand the head will have a sloppy fit. Measure it with a set of dial calipers and see it diameter. If its 1" on the money or some other 1/16 there are premade shafting that has a good surface finish and would only need cut to length and the ends turned to make it look like new for a reasonable cost.
A 15" piece is 25 dollars plus shipping.
Crowbarman55
First thing, lightly grind them out to virgin material, then would use an soldering iron,flux, and a quality solder to fill the dings (Dont use torch, to much heat). File smooth after that.
y'sguy
Tulsa, Oklahoma
I'm thinking you are trying to get this into nice display shape. Hopefully, you don't plan to use it for high-volume, precision machine work!
There are several different ways to rig up a temporary spin rig to polish that shaft. True it may effect the diameter, but most likely it will still clamp down enough to hold it.
I used my grinder and removed the wire brush wheel and fitted a tapered wooden block to it to insert into the column of my drill press. On the opposite end I mounted a couple of small casters to a plywood base. It wasn't pretty but it worked like a charm. came out with a nice satin finish. with a few hours of fiddling and headscratcing. Of course high polih is going to run more time, but you could get it done. It does require more heat.
As others have suggested, you could also just buy a new steel rod. Not as much fun though. :)
IMG_2622.jpegShot of my drill press with the column that was rusted and pitted brown when I got it.
O
Old tool guy
I do have a basic northern tool wire welder. I have also done stained glass work so i can get 60/40 lead to flow. The goal is to get it looking good, i would like to get it working at least to see how it works (supposed to be self feeding) but it won’t be a museum piece or a daily worker. I used my cheap caliper and got about 0.985. I’m going to check the price of a new rod but will probably wire brush it real well and apply a light coat of oil.
CallumRD1
Colorado
0.984" is 25.0 mm.
, i would like to get it working at least to see how it works (supposed to be self feeding) I used my cheap caliper and got about 0.985. I’m going to check the price of a new rod
0.984" is 25.0 mm.
Remember the post where you first mentioned this? I suggested it was made in Europe by I forget who. I'm with Callum, suspect it should be metric.
Also, it won't self feed down that shaft, the quill extends.
Firebrick43
400mm x 25mm Ground and polished shaft or 15.75" x .9842"
$23.67 plus shipping.
Hard to tell for sure but may have turned and chamfered ends so may be a drop in part if you don't mind the 3/4" extra length
  • Like
Reactions: RTM
finn
Do a google search for “polishing a bearing journal.” That will lead you to a pretty simple AI explanation as to how it works. AI suggests a shoe lace or a leather strap, too.
O
Old tool guy
I did a little looking for a new rod and quickly discovered it was probably 25 mm. Didn’t find many options (but didn’t check mcmaster) but the one i found showed a 1” rod for about $15 and a 25 mm rid for something over $300.
I realize the head won’t self feed because it’s clamped tight to the post. The queen is out of town and i‘m trying to finish my honey do list before she returns, hope to finish the drill next week.
O
Old tool guy
Got a sidebar question. See this lever that tightens the dealie on the post? It looks broken. The catalog illustrations i have found are drawings so they are no help. It’s a simple thin rod with a collar on the end, the collar has a hole in the side that looks like it’s for a pin wrench, and there are about 3 threads on the very end. Trying to decide what to do with it.
Maybe there was a ball end on that? Not a golf ball sized, but under 1/2” would be my guess. Do the end of the threads look broken, or cut off?
The first post on this thread shows a simple handle there, so maybe yours is a replacement.
The last post catalog link shows a similar handle to the first.
RoninB4
Under My House
-Not wanting to be fussy about nomenclature but they are NOT regarded as the same. Crocus cloth is a very fine abrasive (800 and higher grit size) used for the last stages of hand polishing and completely inappropriate for what you're wanting to do. Crocus cloth will quickly clog/glaze on anything that hasn't had at least a 600 grit polishing and won't show any benefit of using it.
-While I'm at it, using "sandpaper" on metal is not really a very good idea either. Sandpaper is usually lower quality, loose abrasive particles better suited for woodworking. What you want to use on metal is emery cloth, it's sold in various grit sizes and is a better choice. Why get specific on what you call it? Because if you ask for "sandpaper" you'll get something loaded with garnet, flint, or quartz that readily loses abrasive particles on metal and just doesn't seem to work for polishing metal. Ask for emery cloth and you'll get something with a better bonded abrasive that is more durable, longer lasting, and uses a better type of abrasive particle more suited for metal. Yes they both perform the same task of abrading a surface but how well they work makes a big difference. Horses for courses thing.
O
Old tool guy
O
Old tool guy
Interesting, my clamping handle is on the right side when facing the drill, the ones in the pictures are on the left side. I may try to see if the collar will unscrew.
That's mine, the smaller version of yours.
This is the first pic I referenced
Here is the catalog cut from the last post in the thread
You gotta stay with me, my mind does not move linearly most times. That is why I might have 10 edits in one post, just so people have a chance,🤪
