How to pull a very heavy bundle of cables?
reader2580
Minneapolis, MN
I just bought 450 feet of 1/0 cable that needs to be pulled through a 2" conduit. The cable is very heavy. Two of us could barely lift the spool into the back of my minivan.
It will get cut into three pieces for neutral and two hots. How do I pull that much weight in cable through my conduit? It is Southwire cable that has the slippery coating. I have pull tape I will run through the conduit.
Shiftless
East Bay SFO
I’ve never pulled more than 12 ga. through half inch conduit. So I know almost nothing.
That sounds like a tough job. Is it a totally straight run or are there sweeps? I know there are different grades of pull tapes. Watching the tape break when the pull is mostly done would not be fun.
I hope you are not trying to do this all by yourself.
PCustoms
VT
No ground?
How far is the pull?
How are the bends?
I pulled a 60' bundle (hots were 2/0) a few years ago solo. Stuffing/pulling the additional 25' through the LB sucked and I used a come along.
sparky 1971
Central Iowa
Whatdo youhave available? I have a wire tugger but I've also used tractors, skidloaders, forklifts, avan, and an ATV. If there are only a couple of 90's, pulling it by hand won't be too terrible. Four of us just pulled three 3/0 copper conductors through 200' of 2" EMT with two 90's by hand. I did wish I had the tugger for that one , but we were able to get it done.
mm08822
For starters (and probably too late), this is when the most simplistic conduit routing helps tremendously.
Part of that routing can include a strategic location of an LB to split the run up.
I have cheated in the past and dropped lube in the run as I was assembling it to get the lube where it would be most useful.
(I have even drilled a hole in a sweep and fed it foam in both directions as I knew I would be screwed once I hit that next turn during a pull. Most of my pulls are 1 man only so that can increase the "this *****" factor quickly. (Silicone caulk tells no tales of an errant hole.)
Your pull tape will want to be replaced with rope. Do you have anchor points to attach a come-along to at the recieving end?
MarineScott
W. Pennsylvania
I used my winch, 2500# atv size. Some cable lube and the correct knot for the line. Hook the winch end to the line and re adjust as needed. I welded an A frame to hook my winch to because I had to pull mine up at the garage wall.
R
reader2580
Minneapolis, MN
This will be at least a two person job. I don't have any sort of equipment to pull the cable with, but I might be able to get a Dingo if that would help. I was planning on mule tape as rope supposedly can damage the conduit.
This is a 125 amp circuit. 1/0 is overkill, but I got the wire really cheap on clearance. I would have rather had #1, but #1 would cost double what I paid for the 1/0.
sparky 1971
Central Iowa
I forgot to include ground since I already have the ground wire. The ground will be #4 because I already have that.
115 foot pull. If I recall correctly there is a 45, a 22.5, and a 90.
Two people can pull that by hand pretty easy. Just make sure to stay in sync, one guy pulling while the other is pushing. I'd be using a 1/2" diameter rope, but I already have that available.
dave*99
Coastal NJ
I helped a neighbor pull an underwater LED low voltage light out from conduit in his swimming pool. During initial installation, he put the light in while the glue was wet. Damn that stuff sticks to insulation good.
OK, didn't know that about the glue. Thanks for the info.
the glue for PVC uses a chemical welding process which essentially melts/softens the pvc. this same chemical can soften and eat the insulation on the wire. plus if you drag wire thru the glue before it has set and hardened, youre likely to glue the wire to the conduit making it difficult to remove if needed. or cause the insulation to come off exposing bare conductors to water.... its just not a good idea all around and just the reason why its prohibited by code
mm08822
That shouldn't be too difficult in 2" as it even just meets the fill requirements for 1.25".
Just lube it from the start.
R
reader2580
Minneapolis, MN
My main concern is simply the weight of the cable. Southwire says their 1/0 THHN weighs 372 pounds per 1000 feet. That makes the 450 feet weigh 167 pounds plus the 23 pounds for the #4. That is a lot of weight for two people to push/pull.
The reel of cable probably weighs between 175 and 200 pounds. No wonder it was so hard to get into my vehicle. We probably should have had three people to lift it.
mike93lx
Richmond, VA
If you are pulling in the right direction (into the bell ends) and have it lubed a bit, it should go through without much drama, I expect. You aren't hoisting the cable, just sliding it along the pipe
