I'm trying to install a 12vdc fuel pump relay. I couldn't find a kit in town so I have to cobb one together. I'm copying this diagram. I need a power, ground and switch.
http://static.summitracing.com/global/images/instructions/prf-50102.pdf
The relay is VF4-45F11
The socket I found has the following wires already attached. I can re-wire with the correct colors. Thanks
I have a red wire from the socket going to terminal 30 & 85
A white wire from terminal 87a
A orange wire from terminal 86
A resistor going from 85 to 86
