How to remove concrete driveway staining?
abburns
Alabama
I cleaned a section of my driveway with a 18" surface cleaner with a 3500 psi, 4 gpm pressure washer. I also pre and post treated with a 3% solution of sodium hypochlorite. Any suggestions on removing the brown staining in the attached picture?
Youngandfree
VA
SH doesn't remove brown. I'd try a degreaser or diluted aluminum brightener. Acid removes dirt staining.
Mike S.
Charlotte, NC
Diluted muriatic acid works very well at brightening concrete. I used it for spot cleaning my driveway a couple of years ago when I moved into my house. It's bad for the environment, so I wouldn't suggest using it for large areas unless you can capture the runoff and dispose of it safely.
duneslider
Riverton, Utah
I have a brown spot like that in my driveway and it has been there since it was poured. I noticed it a couple days after it was poured. I am not sure what happened but I do know all my concrete from that pour is garbage...
Montauket
CLR , let it sit for a bit hit it with a stiff brush the rinse. If it’s not to embedded it may lift some of it out. Iron is hard to get out of concrete.
hans109h
Upper Midwest
Mike, besides potentially lowering the pH of a water body what are the risks to the environment?
Hans
yhprum
Brisbane Australia
Maybe sulfamic acid?
CombatNinja
Just stain the driveway a light gray maybe? Would probably make it virtually disappear.
dcg9381
Austin, TX
I was thinking that too, it kinda looks like my driveway that I water based stained. I use HD-6600MMA on top of it (it's slick when wet) but you don't have to worry about some vehicle dropping oil all over it.
ybnormal
minerals from water runoff? this is how my driveway looks. those minerals are slick when wet. even power washing doesn't really help.
zak77
Monson, MA
I am not suggesting you use this however i was very surprised how well it cleaned up a small area of my garage slab when i accidently spilled some Ospho on it. It was only down for maybe 30 seconds but it removed so much staining i was surprised. I rinsed the area with water to make sure it didnt cause any damage.
nadogail
Coronado, CA
I was advised to use a Hydrogen Peroxide solution to remove the brown stains from a bathtub.
To my great surprise the stain immediately disappeared.
