how to remove quikrete cure and seal?
boobag
i poured a new garage apron and i want to put down a good solvent based sealer, to prevent ice flaking.
when i poured the concrete, i sprayed quikrete cure and seal from home depot.
water does soak in and change the color of the concrete now. i just want a good soaking in of the solvent based sealer. how should i remove the acrylic sealer?
Garage Flooring
Grand Junction, CO
If water is soaking in, I would think the new sealer would too. How old is the concrete?
Its generally a good sign but not always 100%
Certain silicates and other products used can mess with adhesion of almost anything. Even if they are not functioning as they should or even if they were not designed as a repellant.
Performing an adhesion test is a good idea with epoxy and other coatings.
Here it depends on what is eventually going down. The OP says "solvent based sealer" Obviously there is less concern over adhesion with :lol:a penetrating sealer
joes169
WI
This is the only solvent-based sealer I've ever trusted on concrete that was previously sealed with water-based curing sealer. We've been using it for at least 6-7 years, and we've never had an issue with compatability, and we use w-b cure/seal on almost all of our concrete flatwork. You're going to have to look for it at a ready-mix yard or professional supply house though, the big boxes aren't going to carry it:
http://www.tkproducts.com/products/water_repellent/TDS/TK290_FinalSeal.pdf
