StumpXJ
So, I finally got the top welded onto my little welding/light fabrication cart and needed to ask what is the best way to get the scale off of the steel. Or, do I just leave it on? It is just a piece of 5/16" thick, 25" wide X 37" long steel plate that I welded to the top of my cart. My intention is to leave it 'raw' and have it permanently grounded to my welder so it will be a grounded welding surface, like most any other fabrication table.
I know how to get scale off of steel, just by using a grinding disc/pad etc, however I dont want to have to grind such a large area, and I dont want to scratch up/gouge the table top. Do I just leave the scale on the steel? Is there and easier method to remove it without damaging the top? some type of wire wheel or flapper? (I tried using a couple regular wire wheel, but it didnt have a chance...)
Here is a pic of the cart without the top, I will post one of the new top tomorrow.
Thanks, James
Thanks, James
, but I usually wear a mask when I grind anyway.
