How to remove tire marks
txturbo
Rosenberg,TX
New concrete floor. Building electors used a scissor lift and left tire black marks all over it. I'm going to use a clear sealer on it. Will the marks pressure wash off or is there another way?
TK-421
Pflugerville, TX
If you've got one laying around I'd try a tennis ball on a stick, depending on how many marks there are and how big they are, but I like the pressure washer idea if there's a lot of them or things getting wet isn't an issue.
firworks
IL
When reading the title of your thread, I was wondering what type of evidence you were trying to hide.:lol_hitti
He could have titled it "How to remove skid marks". :lol:
If they aren't too numerous, I think I remember seeing that scrubbing marks like that with a tennis ball will take them off.
T
txturbo
Rosenberg,TX
Just trying to remove the tire marks from the scissor lift that was used by the building electors. They are all over it. I found and old post about this same situation and several people commented that pressure washing won't do it, but a floor polisher with a scuffing pad will.
rattle_snake
Chandler, AZ
tires themselves are like a giant rubber eraser. Leaves a clean spot, just don't get them to hot...
:3gears:
Or try TSP. or a mild acid solution and a brush. good luck.
Armorpoxy
If pressure washing won't work, then normally any mechanical means such as sanding, grinding, use of a Diamabrush, etc should work.
T
txturbo
Rosenberg,TX
ok....did a little experimenting. The marks aren't as permanent as they look. I threw a handful of sand on the floor and rubbed it around with my shoe and it was coming off. Then i put a little dawn dish soap and water in another spot and it came off pretty easy. So today I'm hauling my pressure washer out there to get after it. It should come off pretty easy with that.
My sealer arrived yesterday.....so I should be good to go for next weekend.
