I have a steel building for a garage. The garage door frame is made from square channels (sheet metal with internal ribs screwed together to make a box frame). The sheet is quite thin (~.054). The original owner welded gate hinges to the frame for the existing barn doors. I'm installing a roll up door and need to remove the hinges. Since the sheet metal is so thin, I'm worried about cutting through the sheet when removing the hinges and beads with an angle grinder.
So how do I grind the weld beads off flush without getting into the sheet metal they're attached to? Is there a special wheel that's good for this kind of thing?
