NC Fabricator25
- Joined
- May 28, 2010
- Messages
- 193
Picked up this freebie bench top a few years back and I need to figure out how to repair it. Had been covered with a piece of 1/4” thick nylon-esue plastic (UHMW?) so I didn’t know the extend of the damage. It’s 1-3/4” thick, 30”x72” and is destined to be a general purpose working bench, I have other better suited flat surfaces for assembly or welding.
The damage is 90% along one of the glue joints, but then veers off into one of the boards for about 10”. It seems like there are 2 options: I can leave the cracked edges as-is, fill with glue and clamp, or rip new edges on both pieces to get a better glue joint, but probably lose 1-1/2” of total width in the process.
The second option seems straightforward enough and will have the expected outcome (and a narrower top), but the first option to just glue it up as-is is unknown to me. Will it work? Too hard to get the edges cleanly together for the glue to bond? Other thoughts from those that have been there and done this?
