how to replace the return spring on a drill press
23ford
Turley America
How do I replace the return or quill spring on my guardian drill press. The chuck was not staying up.....dropping down when done drilling.
BigSteve63
SW Missouri
Remove the nut on the housing opposite the handles - spring is under there. you can order a replacement, but when mine went, I bought a mower recoil start spring for like $3 at True Value.
Just hook the lip of the spring through the retainer cap, slide the tab end of the spring into the split nut, and tighten it several turns to build return tension. There may be a pin stop on the DP body to hold the cap in place and preventing unwind - be careful! They can unwind/come off in a hurry!
