How to seal leaky bowed windows?
Max78
Tucson, AZ
So I'm looking for some advice.
We live in a manufactured house and the windows are trash. They are all vertical sliding and they leak air like crazy. When we first got the place I went around and found that the windows didn't seat fully when closed and there was a 1\4" gap at the bottom. I put some soft weather stripping across to bottom and that helped seal them up. Now years later we are running into the windows being bowed on the bottom and now with the at weather stripping in place it wont allow the top part to fully seal. So I have to remove the weather stripping along the bottom, the center 1\3 is seated on the bottom, but the outer edges have a large gap.
We plan on getting new windows (in a year or 2), but we are looking for a quick fix that we can use in the mean time. Any ideas on what I can use to seal all the gaps? I 'm almost desperate enough to fill the voids with a putty we can remove if needed. We don't ever open our windows, we have a sliding glass door that we use for that.
dougf
Missouri
Do you need to open these windows regularly? If so, some more foam might be the best option. If not, I would tape them shut with HVAC foil tape.
I would be worried about the window frame being bowed on the bottom. Have you checked extensively for leaks? I grew up in a mobile home and remember it being a constant issue with my father resealing the roof every other year.
Max78
Tucson, AZ
We never open the windows, and I might have just found the perfect temporary solution. Indoor window insulation kits that you tape to the frame and then shrink with a hair dryer.
I didn't want to use foil tape because that would super ugly as well as a nightmare to deal with afterwards. It might be a mobile home, but its not trailer park status.
DGersic
DeKalb, IL
Pictures?
Even the cheapest windows should be better than what I’m picturing here.
Caulk saver rope comes in different diameters, maybe stuffing that in the gaps would help.
Foil tape would work, maybe cover it with something like shelf contact paper to make it less ugly. Pick a complimenting or nicely contrasting colour.
Expanding foam fills all gaps, but is also kinda ugly to look at. You could paint it to hide though,
Bert_
NW Iowa
I've got one vinyl replacement window in my upstairs yet. It doesn't seal so I just caulked it shut. Huge improvement.
nadogail
Coronado, CA
I once bought caulk for use when installing windows in the camper tops for pickup trucks. It was very much like modeling clay, thin strips in a roll separated by waxed paper, it was adhesive enough to stay where you pressed it, but easily rubbed off.
Max78
Tucson, AZ
Thanks for all the ideas and info.
I'll get pictures of the windows when I get a chance.
nickelTwin
St Paul, MN
This was probably a product commonly known as "Rope Caulk" or "Caulk Cord" comes in a roll
It is easy to apply.
cr-garagedoor
You can fill all the cracks with silicon caulk on the window's exterior if possible. Silicone caulk will stretch and flex to make a water-resistant seal that will last many years. (though you want a temporary solution, still this option can also be considered for 2 years).
Max78
Tucson, AZ
Here are some pictures of the issue. We had a massive amount of wind that made an absolute mess. . . We have a few haboobs in the summers here to give you an idea of what kind of weather I deal with...
This window was cleaned and spotless a month ago. . . Just sick of the dirt infiltration...
I would love to replace all the little felt weatherstripping on these windows. Anyone know what its called or where I can get it?
