No not really wanting to re-roof but it’s still cheaper then building a whole new one so if that’s what has to be done then so be it. Hoping for a simpler solution. Not so much due to cost but mostly just the time needed to do all of that.Are you prepared to reroof?
Right now you just have metal tin or similar attached to purlins so no sheathing, no weather barrier and not a ton of control for moisture that gets around the seams and fasteners. If you want to seal up the sides for potential conditioning of the inside, the roof probably needs attention as well
Are you wanting to tighten it up to reduce the 3 invaders of bugs, birds and beasts? Or is their a desire to possibly heat or cool it efficiently? Better understanding how you want to use it will better inform the answers.No not really wanting to re-roof but it’s still cheaper then building a whole new one so if that’s what has to be done then so be it. Hoping for a simpler solution. Not so much due to cost but mostly just the time needed to do all of that.
Both, seal it first because we want to use it as a storage building. Later I’d like to condition it if possible.Are you wanting to tighten it up to reduce the 3 invaders of bugs, birds and beasts? Or is there a desire to possibly heat or cool it efficiently? Better understanding how you want to use it will better inform the answers.
Yeah I’ve been looking at it now for awhile and that’s sort of what I came up with also.Install facia and soffit (vented to be prepared for eventual insulation/conditioning) will seal it from birds and many animals.
It’s water tight already. Not dust and critter tight though. Here’s a pic of the roof line that I took earlier. Not sure what you are looking for though.Whats the ridge beam look like?
Im not a framer by any means, but you have widey spaced rafters 24” OC, potentially undersized??? with rafter ties. No birds mouth where rafters sit in top plate.
Maybe spend a few bucks on an engineer and get a plan together.
Looks like a lot of redoing to get water tight.
Time to frame it for soffits and a fascia board. That tin looks like it could use some help as well.
