So I fabricated this wrought iron and cedar picket gate. First gate I've done. Only potential issue I have is that I used 4x4" 0.120" wall square tubing as support posts. Approx 11 ft long, with 3-4 feet in the ground. The hinged side seems to flex more than I expected and I've really had to max out the hinge adjustment to keep it from drooping too much. The 3-4 feet in the ground is reinforced with ~4, 80lb backs of concrete. The ground is not giving way. The pole flexes. That I am sure of.
Anyway, started thinking about how to minimize the deflection of the hinged post. Maybe fill with concrete and then stick 3-4 tubes of 1.5" 0.120 wall round tubing inside there? It would be sort of a composite at that point.
Stupid idea?
Thoughts?
Stupid idea?
Thoughts?
