bad_idea
With a transfer punch of course. Unfortunately I don't have one that large. I found one on Amazon for $25 shipped. I don't want to spend that much on a punch that I will rarely have a use for, if ever again.
I don't have access to a lathe to turn a bushing to use with a 1/2" transfer punch.
I need to transfer (4) 1 1/16" holes from a pump and motor foundation that is approx 4'x5' that weighs 1200 lbs or so. The foundation will be bolted down w/ 1" bolts. The base of the foundation is made of 4x4x1/2 square tube with a steel pipe through the corners for the bolt holes.
I'm thinking use a 1 1/16" drill bit in a hand drill to mark the center of the hole. It doesn't have to be precision, I just have to be able to get (4) 1" bolts in. The steel pipe in the foundation corners should guide the drill bit nicely to keep it centered. Once I have a mark in the center of each hole, then rig the foundation off of the base and use a mag based drill to drill the holes.
Any better ideas? BTW... this is on a ship for a pump feeding a reverse osmosis unit.
