How to turn a 90 with conduit inside wall
highflier
Navasota, Texas
Usually you run conduit up the outside wall to the height of your panel.
Then run the service wire into the back of the panel.
If you can run it inside an unfinished wall, that is acceptable.
P
polar8
San Jose, CA
Where is the panel in relation to the conduit coming out of ground?
The panel is 5 stud bays over, and about 3’ higher.
Bringing the LB to directly behind the panel sound way more practical, but it would have been ugly since it’s in an exposed area... my wife vetoed that. So now I need to figure out how to run conduit inside the wall.
picture hosting
Stuff
You have been screwed by the aesthetics committee.....
I assume that you won't be allowed to run exposed conduit on the inside either. One option is to build out the wall though it would need to be about a foot to accommodate a 90º 1 1/2" elbow. Other option I see is a large junction box with an accessible cover. Most are 4" deep so would stick out of wall a bit.
Next problem will be boring holes for your pipe. The holes might be too big for 2x4s. So convert to smaller copper NM or SE cable at the junction box.
soob
A pro tip: an LB inside the wall is accessible if you can cut a hole in the drywall to get to it.
May not work in all jurisdictions.
Seriously, if there's no splice inside the box, what possible reason could anyone have for caring whether it's there or not?
Maybe you could heat up and bend the pvc or something. I don't know.
Norcal
Dig a little farther to run the conduit closer & bring the LB into the back of the panel, much cleaner installation that way, anything else is going to look clunky.
Hole would have to be cut during install.
Not covered up and left for someone else to find down the road...
ford33
Chicago, IL. USA
Dig further and enter the building from the back of the panel. You can cover the conduit on the outside with wood trim or add a tall flowering plant near the wall.
casmurbax
Wilton, NY
I saw this at the veterinary office I bring the dogs to.
If you moved the conduit over to the same bay you could do something like this:
I know they were installing a whole building generator and I am not sure of the picture where the wall is open was the actual finish of the wiring before the wallboard installed. There was a 2 month lag between the 2 pictures.
signcrafter
You can either put in a junction box with a front cover accessible, install short piece of PVC from LB to J box then go from Jbox to panel.
Second option is to use an LB in the wall and then use one of these plastic access doors. I've used them for plumbing before. Easy to install, just drywall and then cut a hole and silicone in place. Then can be painted or whatever to match the wall. https://www.homedepot.com/p/6-in-x-9-in-ABS-Wall-Access-Panel-34055/100149906
Bert_
NW Iowa
The best way to do this would have been to bring the conduit up though the slab, inside the wall directly below the panel. Obviously it's a little late for that though.
If you put an LB or J-box inside the building, a J-box would be my choice of the two, it must remain accessible. No covering it up in the wall, no permanent cabinets in front of it, ect.
The best option here is bring it up the wall outside the building, then LB into the back of the panel. It doesn't matter what the wife or you think of how it looks, you don't have a lot of options. Besides if you paint the conduit the same color as the siding it won't be noticeable.
rburke65
Canfield, Ohio
If your wife vetoed the original idea, have her come up with a solution! She needs more to worry about. I know....I'm married also. Two years from now you....she....won't even know it's there. Easy for me to say....I'm in Ohio!
PWC Repair
Arkansas
Im also thinking back up a bit, a couple 45s or whatever you need to do, and come in right under the panel.
Bert_
NW Iowa
If transitioning to service cable, that would work. Individual conductors is a no-go.
URD or MHF is still considered a cable since it is made of multiple wires twisted together, but you are absolutely right those types cannot be run though a wall without a conduit.
At this point my vote would be to run conduit up the wall outside into the back of the panel. Paint the conduit wall color and you will forget it's even there.
arkieguide
picture hosting
In my experience - move the pipe on the outside to come straight up to back of panel. Inside yes an LB will work fine in accessible.:spit:
bobbyjean
hudson valley n.y.
dig trench,cut plate,core,chip out concrete and come up inside wall...or take wife to dinner and just come up in the exposed area...bam-done :beer:
Norcal
Another option is to move the panel to the bay where the LB is now & use a 4" deep screw cover can in the wall cavity rather then using a LB in the wall which never should be done under ANY circumstance.
DirtyJersey
X3
Trench over to panel
Or
Heat up a stick pvc and bend it to fit
Sent from my LG-K550 using Tapatalk
P
polar8
San Jose, CA
Can I run my XHHW wires inside flexible conduit in the wall? Like smurf tube. Or does it have to be in rigid conduit.
Bert_
NW Iowa
Sure you can, but any flexible conduit will have a minimum bend radius. It's usually about the same as the pvc 90's you've been using so it won't help you.
FYI, normally "rigid" conduit means the thick metal kind that is threaded.
P
polar8
San Jose, CA
I see. What I meant was, I've already come to terms with needing an accessible LB inside the wall. I was just thinking about what to use from that LB to the panel. Using PVC conduit would mean I would have to chop the straight runs up into multiple sections, to feed it through the studs. So I'd rather use flexible tube if possible.
