How to use a striking wrench?
qqzj
Do you need someone/something to hold the wrench steady while hitting the wrench with a sledge hammer? Sounds pretty dangerous to the guy holding it. If not, what prevents the wrench from flying and hitting someone in the face?
subroc
Dover, NH
We called them slugging wrenches. Hit em' till they ring.
Anyway, hard work on any big stuff can be dangerous. Depending on the application, maybe you can work alone, maybe you need someone to hold it. If you are swinging the hammer don't hit the guy you are working with. If you are holding the wrench, don't get hit.
Only time I saw one in use, one guy had a foot on the nut and wrench, the other guy hit with the sledge. It was easy being on a vertical facing nut. I suspect a horizontal facing it might be a bit more challenging to balance to keep a foot on the wrench.
bwringer
Indianapolis
I'm thinking wooden stick from a safe-ish distance.
I've never really heard of anyone holding a slugging wrench for someone else, but I guess there are situations where that would become necessary.
BukitCase
Oregon
Useta have older VW bugs, axle wrench was IIRC a 37mm striker - also have a "pickle fork" bit for my air hammer, .401" bit. Last time I used that wrench I used the pickle fork (straddling the striker end) instead of a hammer - worked great... Steve
ttpete
Dearborn, MI
36 mm. You're off by 1. Back in the 1960s, we just used impact guns. My 1/2" IR would work fine. Same for the flywheel nut.
