how to wash nuts ands bolts?
tylerae40
western Australia
g'day to all,
i recently bought a few buckets full of nuts, bolts,tools and **** from a deceased estate auction. Unfortunatly all the sheds on the property where full of rats, mice and birds so everything is covered in poop. Im wondering how to wash all the small parts and what with? i also have some bits that need oil and grease cleaned off too. any help would be great. cheers
4EyedTurd
Texas
Would one of those vibrating polishers be worth using for the rusty ones? The ones with a bucket and media
slip knot
Texas gulf coast
I'd go with the wire wheel myself. Get real aggresive with it to. Wont hurt a thing. Might want to have some respiratory protection tho, rat **** is bad on the lungs.
E.rodz
st.paul MN.
go to your local hobby store or ebay and buy a rock tumbler throw some sand in it and let it go.make sure to oil them up after there done!
PCO6
Newmarket, Ontario
I built an air assisted small parts soaker that I mostly use for cleaning hardware and small parts. I basically load up the basket, fasten the lid and turn on the air. I use varsol as the cleaning agent. The parts don't come out spotless but it certainly lessens the amount of cleaning by hand.
Ironhorse
ultra sonic...that is all I use..it is a heavy duty one..and if you put your fingers in while in operation it will etch you bone joints...other then that..it gets the **** off.
HOTFR8
Castlemaine, Victoria. The Hot Rod Centre of Austr
I use Diesel fuel. cleans and lubes. Use a system like the old carb cleaner cans with a small basket. You can aggitate the batch and drip dry.
:+1: Let them soak in the Diesel a few days. Kerosene would also work as a cleaner but the Diesel would lubricate them at the same time. I have a bucket with a small amount of dirty Diesel fuel just for that purpose. Tow balls, D-Shackles etc. all get a soak.
Sureshot
Bridge Creek, OK
Heat your varsol and see how good it works. Is just amazing.
camarotoolman
cocoa Fl.
I wouldn't bother, you will spend alot of time and then not use the stuff. It takes hours to sort it, clean it, store it. Then you never seem to have what you need so you have to run the the store anyway. Been there , done that.
lilredex
Toronto
Smaller lots using Varsol:
Larger, using your HP washer, pre-soaking helps.
Used to work at a place that needed to recondition and reuse hundreds of greasy bolts. They had both a hot tank and steam hose which did the job 100%
PCO6
Newmarket, Ontario
I have not tried heat. What do you use for your heat source? I'm assumimg a submersible heater or "hot plate" of some type.
The MSDS talk about avoiding excessive heat and problems with vapours. I don't think I would want to heat varsol inside a basically closed container like I showed above or in my parts washer which is even more enclosed. I'm open to suggestions but I've been happy with using varsol room temperature.
T
tylerae40
western Australia
Cheers for the ideas everyone, i found some perf mesh laying around at work, so i plan to make a mesh bucket for pessure washing and also a sort of hamster wheel, so as i can have it full of bolts rotating in some diesel or something- probably spend some time making it up, will post pics, cheers guys!
Sureshot
Bridge Creek, OK
The times we used heat was with a submersible heater. Worked amazing. Varsol does not ignite easily but it does burn very hot once going.
We also used to put parts in pails etc for the trip home and the agitation from the bumpy roads etc would clean things pretty well.
PCO6
Newmarket, Ontario
I have a round submersible heater that is made for 5 gal. pails. Varsol boils at about 315*F / 160*C and it won't get it any where close to that. I'll give it a try.
GRX
MD
x2 on Diesel or Kerosene. Thinking of using a tumbler or similar with sand or other hard aggregate ... or where the parts rub together? Thread destroyer you shall be called :evil:
