How to wire single phase 6 wire motor?
Walkers
Cave Creek Az
I have a 5 horse, single phase, 230vac, capacitor start, motor that has 6 leads, going to 3 sets of windings. The wires are the same color, and any tags are long since gone. I can identify each set of windings. How do I wire this?
Thanks,
Cruzan80
Denver, CO
They are not all equal, if it is a 1ph motor. If there are three sets of windings, that usually indicates a THREE phase motor. Unless you mean two windings for run, and a start winding? Any data on the motor itself?
W
Walkers
Cave Creek Az
Most definitely single phase, most definitely 3 distinct sets of windings. I have seen the motor run on single phase power, it is rated single phase. No start switch.
Ummm a 3 phase motor can run on single phase. But youll eventually burn it up if the current draw isnt controlled
Cruzan80
Denver, CO
How is it rated single phase? Is there a motor plate? Seeing it run on single phase power is not mean it is set up for running like that originally.
No start switch meaning what? Almost all single phase motors (especially with start capacitors) have a way of dropping the start circuit out. Either thru something like a relay, centfrigul switch etc.
W
Walkers
Cave Creek Az
what do you mean no start switch?
what I mean by 'no start switch', is that there is no centrifugal start switch.
did you have an end off?
both ends.
it has a single phase 230v rating plate.
Make and model of motor?
have to get that next I am over there. Unfortunately nothing comes up and the company has been absorbed. I want to say it is a Seas, or seyas, something like that.
W
Walkers
Cave Creek Az
See above.
Cruzan80
Denver, CO
Next step would be setting up a drawing showing what goes where, and getting continuity/resistance levels between sets of wires.
Worst case, label them A-F, so we can all talk the same language.
Also, what do the capacitors look like, and how many of them? I have seen 5hp 1ph motors with start caps, and with start/run caps (they looked different).
W
Walkers
Cave Creek Az
The capacitor has no tag on itbut is about 2" around 10" long, single capacitor. It just hung of a bracket on the side.
dogdog
CHeck for ohms and see if all coils are same.l ohm or inductance.
From the plate, that motor most likely a 3ph motor. If you swear it ran on single phase 230v before then check and see if some one have converted it to run single phase with capacitors. One guy did that here with a posting before with lots of info. I just remember its some guy into photo.
PCustoms
VT
:headscrat
How you figuring that?
There's 2 pretty obvious clues on the nameplate that you aren't correct....
Cruzan80
Denver, CO
When I put the name into Google, saw another that had a relay on top. Guessing that is what energizes the start capacitor. Until we know more about the leads, it is all guesswork.
Only way I can make the math work in my head is if the OP is counting two run windings T1-T4, and a star winding T5/T8 to get six wires and three windings in a traditional sense. Or, Asea took a 3ph motor and de-rated it with a start capacitor, to "simulate" a 1ph. Either way, that seems an odd RPM for a 60Hz motor...
@dogdog it does say PSC on the bottom of the pic (top right line of the plate).
dogdog
LOL watching too many videos on UVW 3phase to 1phase motor conversion... those EU guy's brain are wired differently. But at least plenty of videos on how to do it.
dogdog
