How well do commercial epoxy floors hold up?
jserr68594
I am going to be putting up a 40x60 barn. I figured it would be good to epoxy the floor when it is new and has not been contaminated with oil, dirt etc.
I am thinking going with a commercial epoxy like they use in car dealerships would be a good option. I have been quoted around $3 per square foot. Is the price in line?
How well do most epoxies handle wear and tear from rolling jacks, tool boxes, dropping tools etc?
vavet
Ashland, VA
I DIYed my armorpoxy floor a few year ago. I think the DIY price was about $2/sq ft. I think $3/sq foot pro installed would be a good deal, as long as it's a good product. The painter who applied the "epoxy" on our attached garage when the house was built used a Sherwin Williams consumer grade product. I should've known it was too cheap - it was about $1/sq foot. First it had a bunch of pock marks - looked like air had bubbled up through the surface after the coating had been applied. Then they sent him back to do it again. All he did was scuff the surface and go over it again...so all the flakes from the first application were still visible, but now they'd been painted over. I negotiated a refund for the full price we paid and figured I'll grind it down and redo it someday.
When I started working in a BMW dealer in 2006, we had coated concrete floors, but they were working on an addition to the building. When that was completed, BMW required the dealership to bring the entire shop up to the most recent standards, so the whole shop got red tile floor - think subway tile.
It looks great, but the white grout they spec is a pipe dream...they should just spec gray because it ends up being gray after a month. That tile holds up well as long as it's applied properly with enough thinset behind/underneath each tile. Plenty of GJ members have used tile in their garages and it opens up a lot of possibilities for patterns.
I went against the grain and did armorpoxy white with no flake. It always looks dirty. It shows every scuff. I knew that going into it and accepted it. I'm OK with it. I love the reflectivity of the white. I love not losing a small nut or washer against the flakes. Anything I drop stands out against the white floor.
If you decide to DIY - just make sure you apply it thin enough - I went too thick initially and had to buy more...and don't try to save a few bucks and skip the special spike shoes - you will absolutely need them and use them.
Shea
California
Was this a quote from an installer? If so, it would help to know what kind of system they would be installing (type of coating, specs, how many coats, etc.) and what the concrete prep would be. $3 per square foot is less than the national average for installation of a commercial quality floor coating system. A properly installed commercial garage floor coating system will last years and stand up to rolling jacks, normal automotive repair and etc.
J
jserr68594
https://www.sealtoledoconcrete.com/
This is the website for the company who gave me the verbal quote. I think the fact the the building will be brand new with fresh concrete may have kept the cost down? I am not 100% sure on all the details regarding the product they offer, but they do seem to have a good reputation. Thanks for your input!
Andy Smith Jr.
Houston, TX
I don't have the most experience but i did use the Armorpoxy 3 coat system (primer, epoxy, urethane) on my garage. I did a ton of research in advance and the biggest takeaway i had was that urethanes hold up a lot better than epoxies do when it comes to things like pallets jacks, forklifts, cars, etc.
