How would I break this stone mantle?
ive
Canada
Hi all.
Wife wants a wood mantle built over the stone slab. I’m looking to break off the corners of the stone slab not using power tools because of the mess is would make.
How would I break off the corner neat and without a mess?
Thanks so much for any input.
Garcky
Twin Cities Metro Area, Minnesota
Hmm...that could be difficult to do and get a neat edge. I'm trying to figure out why it extends that far from the end of the masonry work. You'd get a better cut-off with a diamond masonry blade, mess notwithstanding. The dust could just be vacuumed up.
You can get a 9" long diamond masonry blade for a reciprocating saw for under $20, here:
  • Like
Reactions: ive
gmcgeo
Angle grinder with a masonry blade. You won't have to cut it all the way through, just score it deeply and whack it with a BFH
^^ this. they beat me to it.
Make sure you have a vacuum running near the area cutting to not make a big mess. and wet it down a bit
  • Like
Reactions: ive
That's what I used to cut some "pavers" in half for my sister.
Be sure you were wearing a FULL RESPIRATOR MASK. (Not a cheapie "dust mask".)
Grinding that stuff sends all kinds of nasty stuff through the air and it's about 37 times finer than talcum powder. Drape off that section of the house prior to running the grinder.
  • Like
Reactions: ive
JRC3
Southwestern OH
I undercut brick hearth extensions and such for flooring sometimes and a good vacuum held at the right spot does the trick. I won't preach about running a bag in addition to the filter in your shop vac right now, but it makes a difference especially on stuff like this.
Monza Harry
Windsor ON
If you use a vacuum get the "drywall filter" for the fines or just throw the vacuum out afterwards, those fines will pass through the motor and trash the brushes and armature. You could consider some water in the bottom of the canister to aid in capturing the dust but that will be messier to clean after the fact. Harry
JRC3beat me to the "Post" button
  • Like
Reactions: ive
engineer2
Chicago burbs
Angle grinder with a continuous rim diamond blade.
Have the wife hold the shop vac nozzle to catch most of the dust.
You only need to cut it most of the way around about 1/4" deep.
Use a hammer and chisel and tap the groove until it breaks off.
Have the wife hold onto it so it doesn't hit the floor. Teamwork!
Norcal
I would hang up some cheap plastic around the work area to contain the dust if a grinder is used. If not done there could be a seriously PO'ed wife & as someone who has screwed up lungs, wear protection.
shoot summ
Just the ends? Or the overhang all the way around?
Traditional is to score with a chisel and break, if any is hanging out too far use a chipping hammer to get it where you want it. There is a mess of the little chips going everywhere, but little if any dust.
As others have stated a diamond blade in an angle grinder. No matter how well you tent and vacuum, you will find dust in other parts of the house, stuff is like Kilroy, everywhere.
If it were mine, and just the ends I would score and break, if you want the entire overhang gone I would just remove the top stone altogether then trim over it with the new mantle.
imagineer
I have no idea if this would work for your application, but...
I bunch of years ago, I was at some craft bazaar with the Missus and watched a local stone artisan cut and shape a stone slab (I believe it was sandstone) using 2 triangle files and a few F-style clamps.
It was a bit tricky to set up, but he marked lines on either side of the slab and held the triangle files on the lines, then secured them using 3 F-style clamps. He carefully tightened the clamps, trying to keep them applying even pressure. He lightly tapped the files using a small hammer, then tightened each clamp, then tapped again. By the 3rd round, the slab split, more or less along the line. STONE CUT_1.jpg
He said he preferred this method because it produced a straight, but natural looking edge.
JRC3
Southwestern OH
If it were me I'd wrap the mantle around that corner to the back wall, something like this. Then you wouldn't worry about breaking it off too perfectly, just enough to cover it up.
919a9eec-c704-406f-9ae7-ca96ead2c647-jpeg.1755105
I
ive
Canada
Thank you all.
Gonna try the chisel. Gonna cover it so dont need it to look nice. And I’m worried about the mess of a grinder.
Thanks again so much everyone. It’s a community here and I love it.
PoorUB
Fargo, ND
You can buy diamond blades for a multitool. They do not throw dust all over like a grinder and cut of wheel. The dust just drops to the floor.
Years ago I had to cut a thermostat box in a hospital room wall. The electricians were supposed to run conduit and put in a box, but it didn't get done. The walls were covered with heavy, 1/4" think glazed ceramic tile. We needed holes in the walls and we couldn't make a mess as the rooms were finished including the hospital equipment.
An oscillating multitool did the job and just a little pile of dust on the floor afterwords.
mike93lx
Richmond, VA
I cant even imagine how long that would take to cut with a multitool
PoorUB
Fargo, ND
Faster than one would think, plus you just need to score it well all around and give it a wack with a hammer.
I have cut ceramic floor tile here in my home and it cuts like butter with the right blade. That chunk on the mantle would take a few minutes.
mogandave
Bangkok
Water will eliminate the grinder dust. Still a mess, but not nearly as bad.
I would not want to whack it too hard and risk knocking the whole thing off.
Be sure to put something under it (besides your feet) to protect the floor...
engineer2
Chicago burbs
That'll work too. Mark your line with a pencil. Use a hammer and sharp chisel and keep striking along the line. Keep going around and it will eventually break off.
CSRPenFab
Meridian Idaho
Lots of great ideas here, but mostly a dust mess. I'd simply take a chisel to the mortar joint holding that entire top piece on and break it all loose. Then just remove the entire top stone.
Uncle murph
Harford county
Hi all.
My nephew could break a anvil with a corncob,let him have it.
strutaeng
Dallas, TX
Have you looked into the idea of removing the piece, cutting it outside and reinstalling it? Not sure if that's possible?
Looks like that's what happened when it was installed: The installer was like, "damn, last piece is too long! Screw it: Send it!"
yeldogt
I would reassess the fireplace and determine what I want it to look like ... I think to make anythng out of it you have to remove the limestone top. I would score behind it to remove the drywall seal and then try and remove the whole top.
If the joint is mortar and wide enough you can make a series of drill holes and then hit it with a brick chisel to crack the mortar joint .... otherwise just a chisel .... the limestone may crack
kaymccampbell
Upstate New York
Thank you all.
Ok, it's Friday. Didja whack it with the BFH? How did it turn out?
Stuart in MN
Minneapolis
How about simply removing it altogether, and replacing it with an all wood mantel. It may be easier than trying to wrap the stone.
archtimb
My thoughts exactly.
Take it from an old contractor. Approach the job as if you wanted to save the top stone for reuse. It will break for sure.
But really, just remove it.
rayra
Escaped from Los Angeles
A brick chisel and watch a couple youtube vids on how to properly utilize it. Several medium taps and a few good blows should cleave off what you want to remove. And do so without all the terrible mess of any sort of saw or grinder.
