BTL-A4
I have a light on a post next to my grill that rotted and fell over. It was just a metal tube set in the dirt. Time to do it right, with a base set in a proper foundation.
I was going to use this to replace it.: https://www.homedepot.com/p/SOLUS-6-ft-Black-Surface-Mount-Aluminum-Lamp-Post-with-Cast-Aluminum-Base-and-Decorative-Cover-Hardware-Included-SM6-NCASTV-BK/314941228?MERCH=REC-_-rv_homepage_rr-_-NA-_-314941228-_-N&
How deep and how wide do I need to make a concrete base for the bolts? I'm assuming just a little deeper than the length of the bolts (allowing for some to stick up to allow attaching, of course). I'm guessing about 2" or 3" bigger than the base piece? I was planning on setting the bolts in the wet concrete.
I live in an area of SoCal that gets hot in the summer and occasionally freezes in the winter, so I want to make sure the concrete will be less likely to crack.
Thoughts and comments?
Thanks!
Thanks!
