HTF 1/2 earthquake or IR 2130 Impact?
mrjaw14
Nashville, TN
TSC has the IR 2130 Impact on sale for 169.99
http://www.tractorsupply.com/ingers...ct-wrench-impactool-1-2-in-drive-2130-3400110
Manufacturers Number: 2130
Brand: Ingersoll Rand®
Drive Size: 1/2 in.
Speed Rating: 9,500 RPM
Maximum Torque: 550 ft. - lb.
Flow Rate: 4.4 CFM @ 90 PSI
Connection Size: 1/4 in.
Variable Speed: Yes
Harbot Freight's 1/2 earthquake is 89.99. They claim 700 ft lb
http://www.harborfreight.com/12-professional-air-impact-wrench-68424.html
Name 1/2" Professional Air Impact Wrench
SKU 68424
Brand Central Pneumatic Earthquake
Housing material Cast Aluminum
Impacts per minute 1085
Maximum speed (rpm) 7000
Maximum Torque (ft. - lbs.) 700 ft. - lbs.
Required CFM 4.4 @ 90
Which should I get?
jaysonb
Good Thunder Mn
I picked up a 1/2 earthquake a few weeks ago, it really seems to be a power house. It is heavy, but for use in my garage, it will work good. Seems to have a bunch of good reviews from the guys around here.
kythri
Lebanon, OR
The only negative reviews the HF Earthquake Impact Wrenches seem to get are from HF bashers.
They get consistently good reviews.
That $89.99 will be only $71.99 if you use the 20% off coupon here:
http://www.harborfreight.com/digitalsavings.html
Plus, you get free screwdrivers. :p
I've got the older style (clone of the IR Thunder Gun), and it's fantastic. I haven't used the new style gun myself, but I've not seen any negative reviews, and if my existing Earthquake gun wasn't so stellar and had disappeared, I'd have no issue going to get the new model.
I can't say anything negative about IR guns (especially when it's clear that HF has cloned their guns after patent expirations), but I personally can't see any reason to spend more than twice the price on the IR gun when I don't think it's going to provide anything more than equivalent (if that) performance.
billymade
New Mexico
There are cheaper places; amazon for $150 or so with free shipping and other vendors for even less;
https://www.google.com/shopping/pro...248874,d.aWM&biw=1280&bih=937&prds=scoring:tp
IR you can rebuild; get a tune up kit for $30, the weight really helps when working with a impact for extended periods of time. The extra money is worth it; durability, availability of parts and support are all worth the extra dough! :)
If you are open to used; many times you can find IR impacts for pretty cheap, the classic IR231's are all over the place and the plastic body ones (craftsman badged version) or the above 2030, are pretty common.... at garage sales, pawn shops, flea markets etc. Every impact I have gotten used; has worked fine and at the worst, just needed to be taken apart, cleaned and put back together. Good luck! :)
Skin
Boston
Home garage? The HF is fine. For daily use though, its on the heavy side.
A tune-up kit that's about half the price of the HF impact...You cant argue with that value, period. Parts are also available for it, just need to place a simple phone call. Both are imported so really, what are you gaining?
mrjaw14
Nashville, TN
From those of you who've used the HT earthquake: does is really put out 700 ft-lb? I know you can't really quantify that, but my general question is do you feel that it's marketing hype, or can it really do it?
The IR only goes to 550ft-lb, but I trust that it'll do that because the IR name is well known.
I'm not getting a good consensus on which gun to get so let me expound on my use. Home DIY use for lug nuts etc. I do have a use for it in exhaust work. My parents van has a leaky seal between flanges and the nut is pretty rusted up. I'm expecting it to put up quite a fight. So if the earthquake can really do 150ft-lbs more than the IR that's significant to me. To get an IR gun that'll do 700+ft lbs is way out of my price range.
kythri
Lebanon, OR
Additionally, I'm pretty positive that the IR rebuild/tune up kits can be used on the Earthquake guns.
I've got a couple kits for the IR 212 3/8" gun that are a direct match for the older style HF 3/8" Earthquake.
I think the IR 231 is the gun that the original Earthquake 1/2" gun was cloned from...
kythri
Lebanon, OR
I think it's a reasonable figure, but, you're right - without some kind of measurement tool, it's not easily quantifiable.
That said, I think that, other than the IR gun being physically lighter, the Earthquake will give at least equal performance to the IR gun, if not better.
86k10
Colorado
I had the IR pictured and it was ok. I did sell it after a couple of weeks and got the 2135. I also have the HF 3/4" and its is good but I would go with the IR over the HF. And might go cheaper and get the 231 if money is a issue.
hickmlg09
I was always told to go with Ingersoll for impact guns or a bluepoint. You can beat the bluepoints up and they still run!
mrjaw14
Nashville, TN
What do you guys think about the IR 231 series? The 231C is a 600ft lb gun. doesn't look like the trigger is variable though. Looks like all or nothing. Anyone have anything to say about the 231c?
joedodge
Tampa, fl
You can run a 231 slow I have one I use every day great gun kinda heavy though the variable trigger thing isn't an issue mines ugly as sin but is a beast and works great
Arbybe
Memphis,TN.
Ebay has a great assortment of air impacts.
I have noticed that here are surprising few HF Earthquake "not working for parts"
I don't know if this means anything,I'm just a mechanic.
I would say that generally speaking,IMHO,they are a "Pass"
Just say'in
JRC3
Southwestern OH
Anybody know if HF offers their two year extended warranty on the Earthquakes? If so another $5-$10 would be good insurance. It almost seems like the ones that failed did it within a year or so of purchase.
Scimmia
Just say'in
You bumped a 2 year old thread for this? Just guessing, but the OP probably already purchased his impact.
lightning02
im not mistaken when i bought mine a 2 months ago i think its been they offered that to me but if i recall it was more then 10 bucks. again i cant recall that well.
arz71
Arkansas
Got some that are IR impacts that are 20 years old and still going strong will second that.
stikman56
Actually the rebuild kits don't work between the two. I believe the original Earthquake impacts were made by Florida Pneumatic. They are bigger inside in areas like rotor output size, etc. therefore bearings won't work, etc.
stikman56
They also have 5 power settings forward AND reverse. Most impacts are just full power in reverse. Variable trigger isn't really much of an issue with all those settings.
Arbybe
Memphis,TN.
You are right, I am new to this site,and I see others reading older posts
I never thought of buying a HF pneumatic tool because of past
Disappointments, then I saw Earthquake being used at a local busy,
Tire shop! So I tried one myself. BEST 40 bucks spent on 1/2" used!
'just getting caught up as I am recently retired.
I've not read any of these posts before so they're new to me.
Just say'in
RBB
stikman56
Just say'in
RBB
I don't pay attention to dates either. Seems there's gotta be somebody to make a deal about it every time someone does. I wouldn't worry about it, let them get their ******* in a wad.
