Can you tell me how to use the special ordered hub top for an outdoor nema 3r panel?
It’s got a tapered pipe thread on it I assume you must use rigid metal conduit? That makes it water tight? Do I need sealant or Teflon tape?
I am actually using the panel indoors because I changed my mind and would like to run the feeder from the top. It would be EMT before getting to the hub.
Also when installing ground bar do I have to remove the white circle stickers first. Or just poke the screw thru is fine ?
