89MustangGX
Hello,
Background:
Several years ago I bought property with a @20x30 shop. It's built as a pole structure. It has traditional siding, but no sheathing - only a tar paper type wrap underneath and studs inside are exposed. It is open all the way up to the roof inside. It is not well sealed - it is open between the trusses (bird block area) and the bottoms of the siding are not sealed well either - I can see daylight on some.
I had noticed a while back that my tools are getting a layer of rust on them, I checked and the humidity in there is very high. It seems to range from 70-85% on average!
I tried a 70 pint-per-day dehumidifier and it filled up with about a gallon of water a day but never really noticed the humidity change. It was in the 80's and went to 70's over the course of a few days, but not sure if that's weather related or from the dehumidifier -- in any event, I don't think it was significant change.
When I moved in, I had a new roof put on the house and shop at the same time. In anticipation of someday finishing the shop, I had roof vents added (8 box-type).
Questions:
Are the roof vents the cause of the excess humidity? Should they be blocked? I have cut a few pieces of 2x2 to help seal the areas at the bottoms of the walls and I can work on adding bird block - but I don't feel like that is the answer to everything. What can I do to reduce the humidity, short of sealing it up and adding HVAC? Do I just need a giant de-humidifier? Or is this all a symptom typical of a shop like this in the pacific northwest?
Thanks,
Adam
Background:
Questions:
Thanks,
Adam
