smalltown
Finally had a few minutes to install a new drain extension at the compressor bottom. Bought enough piping, ball valve, and a simple regulator/filter just to temporarily get air.
Started up the compressor with the ball valve closed, thought it was filling up slowly (my first compressor what do I know ?). Searching around for possible leaks I felt a lot of air near the pressure switch. When I touched the small hose that apparently feeds the unloader valve it popped right off. It looks like a cheap compression fitting on a plastic elbow that has a built in swivel just under the pressure switch. I pushed the hose back into the fitting. and restarted, and at about 60 PSI. the hose blew off again.
Came inside to pull up the owners manual which isn't much help. It's out of warranty, but I'm headed back out to see if it can be taken apart to fix, and or take some pics.
