Husky Air Compressor
03TorchedMach1
http://www.homedepot.com/Tools-Hardware-Air-Compressors-Tools-Accessories/Husky/h_d1/N-5yc1vZb8mrZrdZ5zk1e/R-100653165/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Thinking about picking up this air compressor for the garage. I dont need anything heavy duty...just for airing up tires, blowing out crevices while detailing, running an occasional air tool and what not. It will fit easily under a workbench. Anyone have one or have an opinion about Husky? I looked at a Craftsman with basically the same specs but its $70 more than the Husky.
Gary S
Bismarck, ND
I'd avoid that one. It is an oil-less compressor. They usually scream like a banshee and don't last like a piston pump.
Look for a piston pump compressor of similar size with oil in the crankcase. You will be much happier in the long haul even if it costs a little more now.
35mastr
Norcal
Unless you like wearing earmuffs while using it. I would not buy one. Oilless compressors are very loud. Buy a good quality unit. you will be much happier in the long run. Not to mention that it will last much longer.
jj3
Jersey Village, TX
Hey man, hearing what you need it for I would say go for it. I do actually own it, use it for about the same things you list (do run nail guns, etc as well).
Sure, it is not the quietest/best thing out there, but I can rotate/inflate tires, use nail guns, die grinders, etc just fine.
It is also $20 cheaper then when I got mine some long while ago.
Anyway, just my $.02
JJ
FlashJim
Houston, TX
I have this one and LOVE it!! It was a splurge for me, but I don't regret it one bit.
Husky 30 Gallon
SMKS
USA, planet Earth
Having owned a 30 gallon, direct-drive compressor all I can say is DON'T BUY IT!
My Craftsman worked great but was ungodly loud and vibrated like crazy. If you look around you should be able to find a belt-driven compressor in that size. HF has them, I think.
I don't know the quality of the HF units. They're almost certainly made in China. But, is the Husky you're considering made in China?
A friend also has a 60 Gal compressor that he got at Menards for only $400. That's bigger than you want, but they could have a smaller version more in your price range.
Just my .02
Good luck on the search!
