HVAC design for shop
therealjakeg
Hi, I’m trying to plan out a enclosed loft build and I do not know what to use for HVAC. I will preface that I reside in Arizona, the shop was pre insulated, and I want to cool the enclosed room/loft and the working shop when needed. A few guys in the neighborhood have cooled these with 2-3 ton mini splits.
I have looked at 1 mini split in the loft, and 2 in the shop? Seems a little less efficient but I’m not sure. Any help or ideas to consider would be helpful.
Also wasn’t sure if a standard design would work with a dual zone setup, but not sure if that works since there will be enclosed spaces.
Specs 52’x 25’x 16’ high. Planned on splitting The difference of the loft. 8’ish.
Jackfre
N CA
I would install a 36k btu dual mini-split with two 18k evaporators set on opposite walls about a qtr of the way from the door walls. That will give you the best air circulation. Not sure I follow on the loft as it will be a pretty short space.
danski0224
Near Naperville, IL
I'd start with a load calculation to see what you need for btu's.
If not, then just save yourself some time and copy the other setups if you think it's "good enough".
Mesozoic
Tucson, AZ
I'd perform a Manual J, for sure, but I'd say that a 3-ton mini-split with dual indoor coils will definitely solve your problem. Depending on the quality of the insulation and losses from the doors, you might even be in the 2-ton range, but only a Manual J will tell. Prefer Daikin, Mitsubishi, and Fujitsu as potential brands.
