Hvac Ducting Question
chad pickens
Bloomington , In
Im looking for opinions on ducting a heat pump.My garage is 30x60x11.5 . I have a 4 ton self contained heat pump located in the center of my rear wall, 60 ft side.I have been told to run duct up to the ceiling and put in three vents,one left one right and one straight out. I have four ceiling fans and could use them to help circulate air,but im thinking with that size garage i need to run duct the full lenghth of the wall to get good distribution. what have others done? thanks in advance.
Franz©
in a house
You only need to run ducts 2/3 the length of the wall not all the way.
Ceiling fans will do some of the distribution, but not all of it.
larry4406
Northern Virginia
My garage is 28 deep, 58 wide and 12 tall, and has three bays, the middle bay being a double. My heat and a/c unit is centered on the back long wall. It has a trunk full length on the rear wall being feed from a tee in the middle (unit is below the trunk and 90's up into the bottom of the tee). I have ducts front to back between bays (trunk come towards the front of the garage about 2/3 of the way but won't interfer with the garage doors. I also have trunk taps centered on the end bays, and trunk lines which wrap around the sides of the garage.
Tried to upload pdf's but file size too big, sorry
C
chad pickens
Bloomington , In
Thanks for the info guys. That is what I thought it needed ducting, Now how about what to make the ducts out of ? Duct board or steel rectangular or round. I have alot of osb left over, and a buddy suggested using it to make ducts ,I said what about moisture, but he said since the duct was in the heated and cooled space it should not be a problem.
larry4406
Northern Virginia
I have a loft/living space above my garage. Because of that, all of my garage ductwork is metal, no flex or ductboard. The garage heating/cooling system cannot be connected with the living space above or adjacent lving spaces. My ductwork is all concealed in bulkheads in the garage ceiling and will be covered in 5/8 inch drywall as will the rest of the ceiling. All duct joints are taped with UL-181 listed metal foil tape. The ductwork is then wrapped with flame-spread (silver) type insulation, I think R-5.6. The insulation is provided because I also have a/c. In the summer, when the a/c is first turned on, the ductwork will sweat like a sob here in northern va with the high humidity. The duct insulation will reduce the potential for duct sweating and the resulting mold and funk which can occur in the presence of moisture. The garage ceiling is fully insulated with R-30 kraft faced insulation. The "interior ceiling" of the bulkheads is lined with FSK paper since the kraft paper on the R-30 ceiling insulation is flammable and would not be in direct contact with the drywall. All taps and returns are framed tight. As far as I know, the building Code will not let you use plywood framed ductwork for supplies but it can be done for returns. My heating system is in full compliance with local Codes and is being inspected. Hope this helps.
Vicegrip
NoVA.
You can purchase metal duct for cheap. I am a DIY guy but with the cost of pre made knocked down duct and considering the time spent mucking around with stuff that might not be code your savings might be little if anything.
You might want to at the fabric ducts too. They hang from the roof and inflate when the air comes on collapsing flat when it is off. Fun to watch and you can put vinyl graphics on them too. There are many holes along the front or where ever you want air to blow. Nice even air distribution when done right. Not real expensive and up in a day.
