I have a relatively new A/C units. (9 months old & 2 years old)
The condos are both roughly 800 square feet. 14x8 ducts in 2 bedrooms, plus two in the main room, and then 4x8 ducts in each bathroom.
I replaced the original A/C units (1975) which were 2 Ton GE units with a flat evaporator, vs the "A" style that the newer units come with. They worked good, but the evaporator drain pans were rusted beyond repair and had eventually rotted out the floors underneath them.
The New units are 2.5 ton units to hopefully deal with the increased sun loads on the side of the units, there were a lot more trees around when they were built.
The first one I installed was a rush job, so there is no return plenum, I just use the slide in filter track on the bottom of the unit. It is a 15x20x1 filter.
The second one I installed has a 24" square return plenum with rails that the AC sits on. I have a side cut out and it goes to a 16x20 return grate.
Considering they are new-ish systems, can they handle a high merv rated filter element, or should I stick to the lower rated ones?
The AC with no plenum feels like it blows a lot stronger than the other one, but the only other difference is flex hoses in the attic instead of the 45 year old rigid fiberglass board ducting.
My primary concern is keeping the evaporator clean long term.
What would you use?
What would you use?
