HVAC guys: Good homeowner manometer?
VolvoRyan
Kentuckiana, USA
Hi All,
Long story short: Last year around Xmas, our 23 year-old high-efficiency furnace died (heat exchanger, easy diag). No one was available to install a furnace.... and an unbelievable, pipe-burstingly-cold, cold front was on its way in. So, I ordered a Goodman furnace, took several vacation days off work, and installed the furnace myself. I used a $30 manometer to dial in the gas valve, and make sure the other adjustments were in spec. At 5pm on Xmas eve, with just hours before the temps plummeted, we were up and running.
I'd like to get a better, more trustworthy digital manometer before we fire up the furnace this fall. Any recommendations?
Thanks!
-Ryan
bonneyman
Desert SW
I used a YellowJacket gauge type pressure tester for years, because I couldn't find a tilt scale liquid manometer that wasn't broken. Would loved to have used the old school style, but could never find one usable and reasonable.
Ohmthis
Outside of Louisville KY
For a one time use…..Make your own. A piece of cardboard, clear vinyl hose, tape measure, sharpie, and a dark liquid is all you need. No worries about if it’s calibrated.
V
VolvoRyan
Kentuckiana, USA
Thanks guys! I'll follow up with the suggestions.
Indeed, it might make sense to have a professional come out and give it a good look over. Though, I hate to admit it, I kinda enjoy the work!
-Ryan
PCustoms
VT
-Ryan
If nothing else, you might learn a few tricks. When I did my gas line I had a pro come in and do a couple of flare fittings and pressure test, he complimented my work but also pointed out where if I had added a union it will make my life significantly easier.
finn
The UP, God's country
You can get a simple water manometer from Amazon or probably a hundred other sources. No need for a fancy, and probably inaccurate digital manometer you will probably use once.
No moving parts, simply a graduated vial, some clear tubing, food coloring and water.
When I started working in the engine lab, that’s all we used in the days before digital data acquisition devices. The high precision devices like airflow measurements used a calibrated bellmouth with a pitot tube and an inclined manometer for more precise weddings. The inclined manometers were maybe four feet long and mounted on a board. We also used simple U-tube manometers, as well hand held sling psycometers for determining relative humidity. Labor intensive, but quite accurate
When I installed my propane boiler I used a simple manual manometer. I think it’s still hanging off a pipe in the basement from ten years ago when I did the installation.
V
VolvoRyan
Kentuckiana, USA
That's what I was thinking. Plus, there is some genuine peace of mind from having a professional sign off on my work.
Thanks!
-Ryan
