Blown71X
Ok for my second post tonite (i`m having a bad day bare with me)
First a little back ground:
My shop is 1920 SqFt with 12 foot ceiling R19 walls and R30 Ceiling with 15/32 BC plywood on the walls and 1/2 OSB on the ceiling, it`s fairly air tight with the exception of the freeking outlets (another post) and the overhead doors which i`m working on at the moment.
Furnace is a 4 ton 12 seer air to air orfice type coil with 20kw of electric backup that I installed, mounted at ceiling hight on a platform with only about 5 feet of plenum on the outlet with a spread diffuser pointing at the center of the building.
For the most part it has done well, but last winter it about killed me cost wise during real cold months and I have been watching it and it seems to be running alot so far this year, I checked the charge a couple of months ago with hot gas method and it was close to spec (ambiant plus 110° on the liquid line at the service valve) but i`m only getting about a 13-14.5° rise at the air handler and I seem to remember originally it was in the 23-25° range which I was happy with, All the HVAC guys I know around here are about worthless when it comes to heat pumps and i`m at a loss to figure out what has changed.
Any idea or suggestions on what to check, I know my HVAC background is automotive but this isn`t my first home heat pump install and I have done alot of research due to the lack of knowledge in my area about these and this is the only one that is giving me fits, For some reason in the back of my head I keep thinking that slowing the airflow down a tad across the coil might help but that is the automotive part of my brain kicking in and may not apply.
Thanks in advance
My hair may be gray but I don`t want to pull it all out...HELP
Rick
Thanks in advance
Rick
