600SL
OK I'm getting ready to select a heating and AC system for the garage. Her in NC the most popular units are heat pumps.
But I'm wondering if the beast unit for intermittent use in a garage might be something different and I would think larger.
Using most of the online HVAC sizing tool, I'm coming up with about 3 ton unit for my 48x30x10 garage. But this is a garage and it will have the need to bring the temperature up or down ~ 30° as quickly as possible because it will be off most of the time. So that being said I'm considering 5 ton as a minimum.
Also under these types of conditions I'm wondering if the heat pump is the most ideal over a conventional HVAC system like I had in CT.
Your thoughts.
Your thoughts.
