nhraracer90
Hello! I have a 2600 sq ft building w/ 14ft ceilings. It’s well insulated and so are the garage doors. I have some questions on what possible systems to get.
Self contained unit: I know this unit will sit outside and you just run the duct work right inside. It would be gas heat/ac. What are the pros and cons of this type of unit?
Split unit (air handler inside and unit outside like a house): this would be gas heat/ac as well but I know part of the unit would have to be inside so it would take up floor space or I’d have to build something for it to sit on.
Gas furnace heat only: this would be a propane furnace with heat only. I know this would be the cheapest option and would be inside as well. Could AC be added to something like this later?
I don’t plan on being in there all the time so the unit won’t constantly be on. During the winter I’d maybe set the thermostat to 45 or so. I also have radiant heat in the flooring but it’s not hooked up yet and that won’t be the primary heat source
Thanks!
Thanks!
