HVAC Surge Protector - Yay or Nay?
H
HamAndEggs
Houston, TX
Install the surge arrestor(s?) as close to the expensive parts of the HVAC as practically possible.
For my Mini splits I'm going to install them on the disconnects, but for the main AC I can install it right on the condenser unit. Good idea?
H
HamAndEggs
Houston, TX
Isn't your disconnect like 2 feet from the condenser? Where would you install it on the unit?
Yeah it is, one thing that annoys me though is that I'll have to mount under underneath and therefore sideways. I think it should clear the lineset cover but I'm not 100% sure, would have to measure.
There is a 3/4" knockout spare on the AC unit, next to where the whip attaches from the disconnect. If closer is better, then this is better and more convenient and will keep it out of the rain
H
HamAndEggs
Houston, TX
Got all three installed. The instructions say in bolt to connect to the line side, and the less wire between it and the line side the better (Seems like you'd just install it on the panel in that case?... but ok) So I did just that.
For the ones where I could sneak WAGO's in I didn't double lug. I'm not a real fan of doing that. On the Square D Disco for the main AC I had to double lug because I had nothing to connect a bunch of #8 Together. But those are MUCH larger lugs too
In the end I mounted the one on the main AC like this, not sure how much I like it
dcg9381
Austin, TX
I'm going with a "no". We've had two lightning issues. Both were "nearby" strikes. Lost computer equipment, network equipment, gate controls, AV equipment. Basically anything connnected to cat 5/6. Everything else was fine.
RivennHewn
PNW
We had an outage last Friday.
Power came on/ went off about 4 times in an hour.
The last time it came back on it gave my whole street quite a zap.
70+ houses worth of burnt out computers, microwaves, TVs, GFCI outlets, and heat pumps and more.
My 5 month old heat pump/air handler are both down. As with my dishwasher.
I’m wishing that either my installer or electrician would have mentioned surge protection would be a good idea. I didn’t think about it myself.
Seems heat pumps are susceptible to surges.
Of course the power company will take no responsibility, it’s not like they’re the leading professionals following best practices with every tool known to God and man at their disposal.
