HVAC venting
Buckeye93
Just moved my daughter into a high rise condo downtown. Never lived in something like that. The HVAC is in a large closet. But there are no vents into the closet which to me is crazy. Shouldn’t there be some vents? Any help is much appreciated.
Buckeye93
I should have snapped a pic. But I didn’t. The unit is elevated and the filter is under the unit.
jhelrey
MN
It's what could be called a "MagicPak." The intake for the burner is outside, but behind the grill cover, typically, if not through the cover. The top 3rd of it is the heat exchanger and blower, the lower 3rd is the compressor/coil, and the lowest 3rd is filter and ducting. The compressor/coil/etc. is on a drawer type system. You can pull it out, swap it with a known good one, and slide it back in. The only connection is electrical. Same with removing the drawer, taking it outside, hosing it off, and reinstalling. The rest of it is setup like your house with ducting, etc.
Venting the closet is a fire hazard, therefore, not allowed.
Assuming the association does the maintenance on the unit and it's in a bedroom, do not block the door. If you put a dresser on the same wall, make sure there is enough space to pull the drawer out of the closet with the door fully open, maneuver around the dresser, and out the door of the bedroom.
Buckeye93
Good information. I need to look at it more closely next time I go over there. appreciate the help.
Buckeye93
Says it’s an MB series coil fan unit. Snapped a pic too. Anyone familiar with the unit and should a vent be on the door or wall into the closet to bring fresh air in?
danski0224
Near Naperville, IL
Where's the filter? How is it accessed with the chilled water pipes in front of it? Good ******* luck servicing it with the wall at the front of the cabinet. Someone paid off the city inspector.
There's no way to know what is "right" or "wrong" without a much bigger view of the installation and that closet. And a drawing of the equipment location.
